Originally Posted by mcx
cranking slow.
When it's cranking over slow, how many amps is it drawing? What's the voltage when cranking? Could be the battery is dying, or it could be a starter is going bad. Could also be something as simple as a dirty/corroded battery terminal.
If it's pulling > 300 amps, likely a starter issue - heck, 150 is high unless it's REAL cold. Voltage < 10 under load would be a suspect battery or cables.
FWIW, Harbor Freight has a usable VOM for < $10, and a battery load tester for < $20. Many parts store will also load test your battery for a minimal charge.
