92 3SGTE in 91 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2009, 07:32 AM   #1 (permalink)
Gen2 King
91 Camry's Avatar
Gameroom cash: $161255
View 91 Camry's Photo Gallery
I had just found an '88 Celica AllTrac for sale near me with a 1992 3SGTE in it.
My Question is, would a 1992 engine fit into my 1991 Camry?
it also has a 5 speed manual, would i be able to keep my automatic tranny attached?
And with it being an alltrac, could i just swap the engine, then use my stock tranny to keep it a FWD car?
thanks
-mike
91 Camry is online now   Reply With Quote
Old 12-17-2009, 08:52 AM   #2 (permalink)
7)-73OE Tuning
RL-521's Avatar
View RL-521's Photo Gallery
that motor's a direct bolt in i hear.
if it is a 3sgte, it would be senseless to keep the auto.
it couldnt handle the power. and it would just be, well... slow
wait till charlie posts. he'll give you alot more information.
RL-521 is offline   Reply With Quote
Old 12-17-2009, 09:12 AM   #3 (permalink)
Gen2 King
91 Camry's Avatar
yeah, but i really dont want to go with a fll manual conversion...any automatic options available for this swap/engine?
Old 12-17-2009, 11:03 AM   #4 (permalink)
7)-73OE Tuning
RL-521's Avatar
you can try an auto for a 3sge, form the older celica gt's or mr2's that were equipped with them. theres prolly loads of them at junkyards you can score
although... if you dont plan on building the engine to makes as loads of power, and keep it all stock, then your current tranny may be adequate
Old 12-17-2009, 12:03 PM   #5 (permalink)
Gen2 King
91 Camry's Avatar
yeah i dont plan on making a race car, just want a turbo to make her a lil faster.
would the stock 3sfe tranny fit to the 3sgte?
Old 12-17-2009, 01:03 PM   #6 (permalink)
7)-73OE Tuning
RL-521's Avatar
i would believe soo.
what you plan on doing with the 5spd?
Old 12-17-2009, 01:12 PM   #7 (permalink)
View Wangan's Photo Gallery
If you gonna keep it stock then the auto tranny you currently have should be strong enough....if it was brand new. If not I'd suggest a rebuild.
But lets be honest....you don't get an engine like this and keep it stock for long.... do yourself a favor and convert the car to 5spd. as far as it bolting right in. Iknow mine didn't just bolt right in. There was slight modifications made to the front to rear cross member as engine mounts sit a lil bit more to the right on the GTE.. other than that you just need to get the harness made and the swap should go smooth. As long as you're using a Tranny from a Gen 2 you'll be fine. I'd recommend a Gen2 V6 5spd as you're strongest choice. Or a Gen2 4cyl 5spd if you really think you'll keep it stock.
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
Old 12-17-2009, 01:29 PM   #8 (permalink)
7)-73OE Tuning
RL-521's Avatar
wangan, would a gen2 v6 5sp bolt right up to the 3sfe?
Old 12-17-2009, 01:35 PM   #9 (permalink)
I believe that yes it will bolt up. All 3S blocks have the same bell housing bolt pattern IIRC.
Here's my camry ^
Plans: Here
Old 12-17-2009, 02:50 PM   #10 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The 3s-gte was never available with an auto trans in that motor generation, so you would have to figure out how to control the transmission and figure out what flexplate, etc. would work with the motor. It would be easier to swap to a manual (and much much better for performance!).
The motor itself will bolt in to your car with most of the FWD manual transmissions you can easily find (S51, S53, E52, E153...). You have to get the right clutch setup depending on what trans you choose.
Don't forget the rest of the hassles of the swap - wiring and intercooler piping, among other things.
All of these questions have been answered in various forms either here or on many of the different Celica forums (the Camry is essentially a longer, heavier Celica...). Motor swaps on the Celica are basically the same other than a few minor details (wiring and minor chassis differences).
-Charlie
