Desperate need for Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2009, 07:13 PM   #1 (permalink)
View tnguyen3125's Photo Gallery
OK so my parents want me to use the old 90 Camry because I'm a new driver. SO when first driving the car it was driving fine until after 20-30 mins or so. IT would make a bucking noise and shut off and it would not start again. We would have to wait a while ( like 3 HRS) before trying to start it again.
Now lately it shuts off after 10 mins or so.
My father said this only occurred after driving through some water. It was running fine before.
I don't think it's a heat related problem because the heat gauge thing is normal.
but I'm not an expert.
ANY HELP WOULD BE APPRECIATED
Also Its a 1990 DX Fuel Injected
and i have spent time looking at other threads
and have not found anything smilier to this.
at least i haven't recognized it since i have no knowledge about cars.
SO Thanks in advance
Please i really need this car
tnguyen3125 is offline   Reply With Quote
Old 12-22-2009, 09:48 AM   #2 (permalink)
View joeykrim's Photo Gallery
i am by far an expert but some more detail might help.
when it makes a bucking noise and shuts off, then not starts again. what happens when you try to start it? does it crank and not start? does it make any sense? have you noticed a certain speed or RPM when it shuts off? just looking for some more detail and patterns....the more detail you can provide the better!
Current: 1990 Toyota Camry DX - Intrax Springs (2001), KYB GR2 Struts (2001 front and rear, 2009 rear warranty replaced), Erebuni Bodykit(front uninstalled, side skirts installed), custom cold air intake with K&N filter, very nice stereo and car alarm.
http://car.joeyconway.com
joeykrim is offline   Reply With Quote
Old 12-22-2009, 11:28 AM   #3 (permalink)
well. it would start up fine and run a for little.
going like 25 MPH it would be fine but when i would slow down it would start to stutter. When that happens the stuttering gets a lot worst and just shuts off. I don't have a RPM gauge so I couldn't tell you.
and when i attempt to start it back up
it cranks ( if thats the right term)
but does not turnover.
BUT sometimes it just skips the stuttering part and shut off
and i guess my definition of bucking and stuttering are the same if that helps.
Old 12-22-2009, 12:07 PM   #4 (permalink)
camrygt4's Avatar
Gameroom cash: $178405
View camrygt4's Photo Gallery
take off the distributor cap make sure there isn't a bunch of oil inside
1988 Camry Alltrac LE 5spd with 1991 3sgte swap
1995 Camry SE V6
camrygt4 is offline   Reply With Quote
Old 12-22-2009, 04:37 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Check for water and/or oil under the distributor cap (like CamryGT4 said).
It is most likely either an oil leak causing ignition problems or a cracked ignition coil (located inside the distributor on this car) causing the problem.
Let us know what you find out.
-Charlie
Old 12-22-2009, 05:26 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
water in the cap
Old 12-23-2009, 02:39 PM   #7 (permalink)
Thansk for the advice.
Im going to check on that today
when i get a chance
and
see what happens
Old 12-23-2009, 11:03 PM   #8 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
Find anything?
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 12-24-2009, 08:55 AM   #9 (permalink)
No I asked my dad about it and he said that he checked those problems already.
He think maybe something wrong with
the thermastate(spelling) maybe?
Or the water pump?
Could those be possible reasons?
Old 12-24-2009, 12:44 PM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
no it can't be the thermostat.... that would cause your temp gauge to move around when you're driving.. and if the water pump is leaking you'd know it.. you'll have a big pool of coolant on the floor. and if it's stuck the car would over heat... we're all pretty sure that your coil is bad and that's built into the distributor..
Old 12-24-2009, 06:27 PM   #11 (permalink)
View 270+Camry's Photo Gallery
fuel pump/filter? dirty injectors? gas spark air make ur car run, if ur old man says u got spark, and a good spark, check gas and air next.
270+Camry is offline   Reply With Quote
Old 12-25-2009, 09:04 AM   #12 (permalink)
Just an Old Guy
MrBill91Camry's Avatar
View MrBill91Camry's Photo Gallery
Sounds like a module problem in the Distributor. My brothers 92 did the same thing
MrBill91Camry is offline   Reply With Quote
Old 12-25-2009, 06:52 PM   #13 (permalink)
Zod
View Zod's Photo Gallery
I'd do a tune up with a new coil. Plugs, cap, wires, rotor and coil. Air filter as well..
You'd be surprised how many drivability issues can be cured that way..
Zod is offline   Reply With Quote
Old 12-26-2009, 08:30 AM   #14 (permalink)
Gameroom cash: $812301
View zythr's Photo Gallery
Could be fuel injectors. We owned a car that did that, turned out it was the fuel injectors.
zythr is offline   Reply With Quote
Old 12-26-2009, 10:25 AM   #15 (permalink)
As Charlie mentioned earlier, cracked ignition coil inside the distributor happened on my 90 Camry at 180k miles. It was only slight and just starting, but my great mechanics knew to look for it based on the age and history of our cars.
A tune up is also a great maintenance item as mentioned by Zod, plugs, cap and wires. It could clear up your issue, but when I used some generic napa parts and the plugs and wires feel apart after 1-2 years, I experienced a long lag on acceleration and as they got worse a lot of stuttering when accelerating. Now, I only use the Toyota cap and wires along with the Toyota recommend plugs, Nippon Denso and NGK. Let us know what it turns out to be! These are great cars but on occasion they need a lil love to keep them running smoothly!
