Tranny problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2009, 08:16 PM   #1 (permalink)
View Death_Bomber's Photo Gallery
Tranny problem
Hello first of all, I've been a hidden guest just reading but now i need to post.
I have a 1988 auto 4dr . but kinda sceptical on what model.(power locks, windows,seat belts)
We've recently blown the radiator but wasnt able to tow and had to drive it about 5-10 miles home. we replaced it. but now think it has a blown head gasket. Besides this problem we have seen a decrease in HP. the ability to get up and go.i've got 1 opinion saying its the torque converter. does anyone know the trouble and cost im getting into?
Death_Bomber is offline   Reply With Quote
Old 12-22-2009, 09:20 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
what do you mean blown the radiator ?? was it overheating and didn't have any water but yet you kept driving it ? If it is the HG you'll be having white/blue-ish smoke out the exhuast do you have this ?? check the oil cap and see if the oil is foamy.
Old 12-23-2009, 11:01 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
With blown head gasket the car will lose power, sometimes a lot of power
Doctor J is offline   Reply With Quote
Old 12-23-2009, 11:59 PM   #4 (permalink)
well im not getting colored smoke but im going throug coolant maybe 1 bottle a week. sometimes it backflows into the overflow and out onto the battery.
As for the radiator blowing....i have no idea why it went out. driving just find then boom coolant all over the windshield
Old 12-24-2009, 01:05 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
and then you drove it 10 miles?
Old 12-24-2009, 06:20 PM   #6 (permalink)
View 270+Camry's Photo Gallery
reason u need radiators is cause heat kills ur engine, too much heat can warp the metals, expand them and make them not fit like they should, not to mention what heat can do to ur heads. engnes are supposed to be mighty snug and tight so something warping can cause serious loss of power.even if you didnt blow you head gasket you could loose compression on over heating from cylinder taper/out or round or the rings letting blow by through
drain some of the oil to see if its milky, if it is, thats not good. check to see if you smell a very disctinct sweet smell coming from the exhaust (coolant smells odly sweet)
try to find someone with an available cylinder compression kit and test ur cylinders to see if any of them are way bellow the pressure of the other ones. another way to see if you blew a gasket or have an internal leak is to find someone with a pressure cooker and hook it up to ur radiator and pump it up to whatever pressure ur radiator caps says it holds. if the pressure drops then you have a leak somewhere. i know some guys that buy that glow fuild that comes in a small bottle and they dump it into their engine. if it leaks, they take a black light around the motor and see where the glowing is coming from. that fluid is supposed to be harmless to ur engine. i am not aying to get a couple highlighters cut them open and dump them in ur engine. by the way when ur car is hooked to the preassure cooker (its not a real preassure cooker, thats just what we called it ) and ur motor is leaking from somewhere, it will be easy to find for the most part because you will hear it or see it, especially if it is anywhere near your radiator or radiator hoses.
270+Camry is offline   Reply With Quote
Old 12-25-2009, 05:06 PM   #7 (permalink)
View joeykrim's Photo Gallery
I never heard of the glowing fluid but that's a very clever way of checkin for leaks! I hope I never have to use it but its good to know and keep in mind!
Current: 1990 Toyota Camry DX - Intrax Springs (2001), KYB GR2 Struts (2001 front and rear, 2009 rear warranty replaced), Erebuni Bodykit(front uninstalled, side skirts installed), custom cold air intake with K&N filter, very nice stereo and car alarm.
http://car.joeyconway.com
joeykrim is offline   Reply With Quote
Old 12-26-2009, 07:01 PM   #8 (permalink)
i will check compression, but i think i've got collant leaking somewhere on the front of the block itself. cracked block from overheating it? it was still drivable for at least 2 months
