Yes it is like a spark knock or if I got hold of some bad gas..only it seems to only be comming from the left rear cyclinder.cyclinders. This seems, from other posts here and like form sites, to be something of a "common" issue at the mileage range my truck motor is. (150,000-175,000) I was hoping to find out if any of the other posts found out if it was the valve adjustment, piston, rod or main bearing or broken spring. With this list of possible causes I was hoping someone had narrowed it down.
Just changed spark-plugs, I also do not have access to a computer on weekends, mine is being repared was not snubbing you, just can`t answer or responed.
Thanks for Taking The
Time....
Daryl
