Oil Leak Fix Parts Required?
I have some pretty serioius leaks going on in the front of the engine on my '91 Camry DX (3S-FE) (w/ 210K miles). Since it's a daily driver, I need to order my parts up front.
Here's my list:
1) Oil pump (I suppose I could just replace the drive shaft seal and o ring seal, but figured replacing the whole pump makes more sense).
2) Crankshaft seal
3) Oil pump to block gasket
4) Oil pump strainer gasket
Does anyone have a part number for 3) and 4)? I've been looking at 1sttoyotaparts.com and don't see those items listed.
Edit: I'll also being replacing the timing belt. So far as I know the idler pullys and spring are original. Would it be a good idea to replace them too? The water pump was done at the last timing belt replacement.
Thanks - Paul
