Originally Posted by bigblackcat
I checked for codes today. The check engine light flashed twice, then again. Then a long pause before it did it again?
Are you saying two flashes then another two flashes? That indicates code 22, a Open or short circuit in water temp. sensor signal. This should not cause a no start condition.
Have you checked timing to see if T - belt has not slipped a tooth?
Are the spark plugs wet with excessive fuel? This could indicate a fuel pressure regulator problem.
Are you sure you are getting a healthy spark? Is the spark checker you are using the adjustable kind where you can adjust the gap so the spark jumps 10,000, 30,000, 40,000 volts etc.?
Is this a 4 or 6 cylinder engine?
