Turbo 1989 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2010, 07:29 PM   #1 (permalink)
JDMCAMRY(turbo soon)
View JdmCamry's Photo Gallery
Japan Turbo 1989 Camry
I am currently in the process of turboing my '89 camry. I'm real bored with the camry stock and since i have turboed tons of cars this seems like a fun project for some strange reason. The 3s motor is obviously a kick ass motor and it being the same as the MR2 i got the manifold and the CT-26 turbo off one. I am currently out of work so it will take a while to buy the sandwich plate feed and drain lines, intercooler and blow off valve. This car is a keeper, I will add the roof rack and thicker rims after my taxes
MORE pictures will be added as i get more parts and install them!!!!
JdmCamry is offline   Reply With Quote
Old 01-18-2010, 01:38 PM   #2 (permalink)
7)-73OE Tuning
RL-521's Avatar
View RL-521's Photo Gallery
anyone know how much psi that motor can handle? it cant be more than 9.
good luck with this btw. cant wait to see what it can do. ive always wanted to boost a 3sf
RL-521 is offline   Reply With Quote
Old 01-18-2010, 02:06 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
sweet project. I know i've seen people on here take on this project before. good luck!
'07 Honda Ruckus Big Bore
Old 01-18-2010, 02:24 PM   #4 (permalink)
I am sure to finish this.....I hope lol. I know i wont be boosting more then 7 pound so i will regulate the internal wastegate i dont want to boost anymore then that. It looks like a pretty simple set up, and the car will look as sleeper as possible, i hope, no fancy exhaust bright colors or 20's, not my style lol
Old 01-18-2010, 03:36 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
For the feed/drain line, use the stock CT-26 stuff. You will need to weld/braze on an AN fitting for the feed line (then T off the pressure sender) and weld a bung on the oil pan or use an Celica Alltrac (ST185) pan for a direct fit.
Use the stock wastegate pressure on the turbo, which will be 7-9psi, get an intercooler on there, add an FMU for more fuel under boost and you should be good to go. Oh, and consider getting a new fuel pump (Walbro, etc.) to be safe.
-Charlie
Old 01-18-2010, 04:53 PM   #6 (permalink)
mcx
View mcx's Photo Gallery
nice job...great pixs,it makes it seem like a easy upgrade...you think the exhaust downpipw will have enough clearance??
mcx is online now   Reply With Quote
Old 01-18-2010, 05:24 PM   #7 (permalink)
I didnt get any of the lines from the turbo, i have the flanges, but maybe if i can find the lines at a junk yard or ebay im sure it will be cheaper. I never thought about the fuel pump thanks for reminding me . The intercooler will be from an Mr2 figuring out the placement is pretty brain puzzling, i dont want to run to many pipes as for the mr2 side mount, its a pretty small intercooler i hope has clearance above the area where the compressor connects to the stock airfilter. If the internal wastegate gives me that much boost im sure the motor can handle it.
As for the down pipe, Im looking on ebay and tyring to get some measurement, there is enough space for the down pipe for the mr2, all trac celica and camry. They only thing that looks if-e is the dipstick, looks like a bother. If it wont fit i will just get the down pipe flange and custom make the whole exhaust myself.
2002 Impreza wrx Rally puppy 5 speed
1989 Toyota Camry 5 speed
Old 01-18-2010, 05:54 PM   #8 (permalink)
mcx
..you could substitute a water/meth injection for a IC.
Old 01-18-2010, 08:21 PM   #9 (permalink)
white90dx's Avatar
Run that intercooler in front of the radiator... you'll have trouble getting any airflow in the engine bay (even with a hood scoop or whatever).
Easiest would be to delete the A/C and run the pipes in and out next to the radiator.
-Charlie
Old 01-19-2010, 11:48 AM   #10 (permalink)
I looked into the the water/methanol injection, its not as brain puzzling, i could route the compressor outlet straight to the intake manifold, and add the needle injection to the air inlet to spray. But i will still need the intercooler for the reason being it doesnt look like constant cooling Thanks for making me read up on water/methanol which i never knew what it was.
I measured the space in front of the radiator, if I reroute the horns and remove the bracket holding them, taking off the grill would give me more clearance and more airlflow, the metal bumber issue i can solve, drilling for the piping is what i am looking at now. THANKS!!!
i will try to drop the oil pan for its drain fitting sometime this week if the "storm" goes away any time soon.
Old 01-19-2010, 12:43 PM   #11 (permalink)
mcx
you only need the cooling at full throttle and that is where the water/meth injection will be activated..it cools better than a IC...saves weight..adds fuel with the meth...easier to mount than a IC..never gets heat soaked like a IC ..keep reading up,i bet you change your mind...I USE a system on my turbo 88 200sx.
Old 01-19-2010, 07:41 PM   #12 (permalink)
View nuron's Photo Gallery
Takes lots of pics!
nuron is offline   Reply With Quote
Old 01-25-2010, 12:00 PM   #13 (permalink)
7)-73OE Tuning
RL-521's Avatar
Originally Posted by nuron View Post
Takes lots of pics!
+1
Old 01-25-2010, 01:21 PM   #14 (permalink)
LOL i will, If i don't drink to much while I'm installing it I will try to take step by step pictures. My big check comes in this weekend so i will go shopping for everything I need SO EXCITED!!!! I just installed a roof rack here is a pic....TURBO PICS COMING THIS WEEK!!!
Old 01-25-2010, 04:30 PM   #15 (permalink)
white90dx's Avatar
Somebody let their subaru friends at that hood...
(my old primer hood had drawings of GC/RS hood vents and scoops on it for a while...)
-Charlie
