the rear are drums. Take off the drum and it may be rusted on there so if it doesnt come off get a torch and heat the shit out of 1 small spot close to the hub to break it loose. A big hammer helps too. OR the shoes are holding the drum in place. Remove rubber cap from drum face, use a flat head screw driver to loosen the automatic tensioner.
Once its off check for 2 things.
1) Check to see if there is any brake fluid leaking from the wheel cylinder. Look for humid spots behind the brake linings. If there is leaking fluid replace the wheel cylinder. If all is well continue on to step 2.
2) Check the shoe lining thickness, if they are wearing thin replace them. You will have to turn down the adjuster to fit the drum back in place. Dont install the wheels yet. Start the car LEAVE it in park, pump the brakes until the pedal gets stiff. Now this should automatically adjust the rear shoe tension. When you go back to the drum try and spin it, if it has a little bit of resistance it is good if it spins free go to step 3.
step 3
Remove rubber cap on drum face, spin the drum hole to about 1 oclock if my memory serves, stick a flat head screw driver into the hole and turn the brake adjuster gear until there is light resistance on the drum (it does not spin freely) Again if memory serves you spin the gear down on the passenger side and up on the drivers side. You will hear "click, click" and a springy sound when you do this which indicates you are adding tension.
