You are probably going to have to start removing interior parts of the car until you can figure out where the water is coming from.
Possibilities:
Door seals
Rear quarter window
Trunk Seal
Outer tail light seal
Sunroof (if equiped)
See if you can spot a 'clean' trail from somewhere that water dripping in would cause.
I just found out that I have a leak somewhere in my Alltrac... It doesn't seem to leak with a high-pressure car wash, but sitting there (or driving, not sure) in last week's torrential rains in SoCal caused about 1/2" of water in the rear wheel well... I know the tail lights are sealed but everything else is a possibility still.
Also, the front and rear footwells are connected, so the leak could be in the front or the rear for that one.
-Charlie
