help me diagnose this oil burning problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2010, 09:28 PM   #1 (permalink)
View 89Wagon's Photo Gallery
Had my 89 Wagon for about 3,000 miles, it has 104k on it. Since I got it it seemed to always puff white smoke, and it increased when I got on the gas. Oil magically disappears, but the car doesn't leak and I've done very thorough inspection. Compression is 170-180. It nearly overheated a while back. It uses about a quart per tank or 2. I pulled all the plugs and #4 seemed to have oil/ash deposit, and when looking down the cylinder that piston looked wet or oily. It may be burning a touch of antifreeze, but minimal.
Any experience or ideas? I don't know much about the valve seals, I may just take the dive and pull the head to see if it's a headgasket problem. Any help is appreciated.
89Wagon is offline   Reply With Quote
Old 02-16-2010, 09:44 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Check the PCV hose and 2 PCV channels in the throttle body. They may be plugged.
There are 2 ports in there: one opens to the gasket flange between throttle body and the intake plenum [it is hidden behind the gasket; located on the side that faces the radiator] .It was plugged up on my car so I took the throttle body off and cleaned this passage using carburetor cleaner.
This should be done before tearing the engine down.
Doctor J is offline   Reply With Quote
Old 02-16-2010, 09:49 PM   #3 (permalink)
I failed to mention it's the 4 cylinder. I didn't think the 4 had PCV valves?
Old 02-16-2010, 10:38 PM   #4 (permalink)
View DM89's Photo Gallery
the 3sfe doesn't have a PCV valve but it does have a PCV hose.
DM89 is offline   Reply With Quote
Old 02-18-2010, 04:52 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
rings, just keep some oil in the trunk
Old 05-14-2010, 08:08 PM   #6 (permalink)
bluesguitarboy's Avatar
View bluesguitarboy's Photo Gallery
Oil could be leaking pass your valve seals. If you find coolant in your cylinders you have a head gasket leak.
bluesguitarboy is offline   Reply With Quote
Old 05-14-2010, 10:15 PM   #7 (permalink)
Drove to the Dark Side
JayP71's Avatar
View JayP71's Photo Gallery
Just had a more severe version of your problem. My issue wound up being a pair of bad valve guides. I just went ahead and did a complete engine rebuild rather than just a cylinder head. Roughly $1000 after parts and the machine shop doing the head.
If it will be awhile before you can manage to fix it run a quart of Lucas Stop Leak through your car. It really slowed down my oil loss until I could fix the engine.
JayP71 is offline   Reply With Quote
