If its the clutch, you have to pull the trans... if its the trans, you have to pull the trans...
Its hard to tell what happened from here, but the clutch disc could have exploded or something similar, or the ouput gear on the trans could have exploded...
If the clutch looks normal, its an internal trans problem, if not, replace the clutch and you are good to go.
-Charlie
