missing releys - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2010, 10:50 AM   #1 (permalink)
View jon-jon's Photo Gallery
Question missing releys
Hello
Im trying to start a 3s-fe engine and i have a problem
there are missing thinks that i dont know what they are
can any one help me by :
* telling me wich of them is important to start the engine ? or show me any picture of this box full
( i dont care about lights - turn lamps - glass cleaning & heater & other motors )
* giving me a link for a 3S-FE wiring diagram
At a sign on vehicle wrote : 3s-fe -87 * sv21
my english are not very good so forgive me for any mistakes
Thanks
jon-jon is offline   Reply With Quote
Old 02-20-2010, 04:17 PM   #2 (permalink)
Gameroom cash: $302555
You can go over to the Camry forum over at AutomotiveForums.com and download a Toyota factory service manual there for free. The manuals are stickied there at the top. Download the generation 2 manual. It will have a generation 2 wiring diagram in it.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
jon-jon (02-21-2010)
Old 02-21-2010, 08:23 AM   #3 (permalink)
i found the manual and now is clearly
Thanks a lot Mike
Old 02-21-2010, 01:36 PM   #4 (permalink)
Thanks a lot Mike
You're welccome.
Mike
jon-jon (03-03-2010)
Old 03-02-2010, 02:54 PM   #5 (permalink)
Somehow a plug is cutted , im trying to find the cable of the fuel pump and
i need to know one information
When the key is turned at ON (lock - ACC -ON - - Start) is the pump working for a few seconds ?
If you know or you can test it by hear your camry please let me know
Old 03-02-2010, 05:14 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The fuel pump is powered only when the key is in the start position or the AFM flap is open. Either one of these things will turn on the "Circuit Opening Relay" that should be located in the harness near the ECU.
When the key is turned to the "On" position without starting the car, the fuel pump does not prime with the Camry 3s-fe.
-Charlie
Old 03-03-2010, 05:57 AM   #7 (permalink)
Thanks for your answers ,
i see you are not agree :/
csaxon are you sure this happents on 3S-fe ?
white90dx what is the ? AFM flap ? is throttle ?
if white90dx is rigth i think i find the cable
Old 03-03-2010, 01:01 PM   #8 (permalink)
white90dx's Avatar
AFM = Air flow meter. It is the box with the flap inside that measures the amount of air that is going into the engine on the Camry/Celica 3s-fe (and many other Toyota motors from the '80s and '90s). It should be attached to the top half of the airbox. When the flap is slightly open or more, a switch internally keeps the fuel pump on via the circuit opening relay. The circuit opening relay also recieves power when the key is in the "start" position.
The throttle body and throttle cable do not control the fuel pump power in any way.
-Charlie
PS. You can also power the fuel pump (temporarily to check things) by connecting the "FP" and "B+" connections on the diagnostics connector.
The Following User Says Thank You to white90dx For This Useful Post:
jon-jon (03-04-2010)
Old 03-04-2010, 05:53 AM   #9 (permalink)
Thank you very much Charlie , very interensting informations
In there must be the AFM
and thoose are connections you are talkning about
am i right ?
Old 03-04-2010, 01:21 PM   #10 (permalink)
white90dx's Avatar
Yes, both are correct.
The engine will not run without a working AFM (green arrow) and fuel problems and circuit opening relay problems can be debugged using the connection you showed in the diagnostic plug.
-Charlie
jon-jon (03-07-2010)
Old 03-07-2010, 10:12 AM   #11 (permalink)
its ok whith the fuel pump cable , i found it
now im trying to find why its not have spark , this looks more difficult :/
any opinions are welcome
Old 03-07-2010, 10:34 AM   #12 (permalink)
These engines had a tendency to have the coil go bad on them after many miles. The coil is located inside the distributor. I would check that first for a no spark condition. To do that you will need a digital volt/ohmeter and the specs from the manual.
Mike
Old 03-07-2010, 12:01 PM   #13 (permalink)
Hi Mike
you mean this ?
what i have to check here
Old 03-07-2010, 03:11 PM   #14 (permalink)
Somewhere in the manual you should find the specs for the ignition coil itself. It will tell you what the resistance should be in ohms and what specific terminals to test. In the newer manuals it's in section IG. I'm not sure about the generation 2 manual.
Mike
jon-jon (03-13-2010)
Old 03-13-2010, 01:43 PM   #15 (permalink)
there was a few days with bad weather this is why i late
today finaly i see spark , it was a ground point forgoted :/
i will try next days to stat it , i have to find new fuel pump
John
