91 Camry distributer o-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2010, 08:08 PM   #1 (permalink)
View BobMod's Photo Gallery
I have a 91 camry with a 2.0 engine that has a distributer leak. I have replaced the distributer o-ring. While the leak is not as bad as before, it still does leak a little. A friend suggested just using a thicker o-ring. Has anyone had any success doing so?
BobMod is offline   Reply With Quote
Old 02-28-2010, 03:47 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
Thumbs up
get the timing where you want it and take a pick and scratch a line on the housing and the head, take it out and wipe off all oil and smear ultra grey or black silicone on the flat surface on the head around the hole and put it back in and align the scratched line, let dry, only wish all the other oil leaks were this easy to plug up
The Following User Says Thank You to fredk For This Useful Post:
BobMod (03-01-2010)
Old 03-01-2010, 07:48 AM   #3 (permalink)
Thank you fredk. I'll give it a try.
Old 03-01-2010, 03:31 PM   #4 (permalink)
Gameroom cash: $302555
Did you replace the o-ring with one from the dealer? If not, I would try that first. O-rings can be made from different materials. Some are more resistant to oil than others.
Mike
Old 03-01-2010, 04:26 PM   #5 (permalink)
1990 Camry 3S-FE
Big_Z's Avatar
View Big_Z's Photo Gallery
My 1990 has the same problem. I'm just taking it to the shop in the morning. I don't have the tools to do myself, or the time. I was quoted $225 for rebuilt distributor installed.
Big_Z is offline   Reply With Quote
Old 03-01-2010, 04:32 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
holy crap
Old 03-02-2010, 08:26 AM   #7 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Many years ago, my distributor O-ring went bad around 100K. I changed it. It started leaking again around 130K miles. When I checked, that's when I realized the oil was leaking through the distributor.
Since I wasn't going to keep the car for long, I bought a used distributor for about $100
This seems to be a common problem. If you are handy guy, you can buy a distributor seal kit for 3S-FE engines for a reasonable price.
http://cgi.ebay.com/ebaymotors/Distr...Q5fAccessories
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
