Get the adapter plate from Ebay. They are really cheap.
Adjusting the timing is just like any other motor... Warm up motor, loosen distributor, jumper the "T" and "E1" connections in the diagnostic connector in the engine bay (this is the only 'secret), use a timing light to adjust the timing up a few degrees (12-15* BTDC), remove jumper, tighten distributor and go for a test drive.
-Charlie
