Lost of power on my 1991 camry... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2010, 12:32 PM   #1 (permalink)
View 2jzrps13's Photo Gallery
2nd Generation Lost of power on my 1991 camry...
i have a 91 camry and it was running very smooth but the water pump started leaking so i replaced it but after a few drives it seems to loose power specially when going up hill... what can couse this problem?
2jzrps13 is offline   Reply With Quote
Old 03-05-2010, 01:41 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The timing belt is probably off by 1 tooth. Check and adjust - it should be easy to do by just removing the top timing cover and doing a "quick" check.
-Charlie
Old 03-05-2010, 03:58 PM   #3 (permalink)
ok so just remove that and check it but how do i really know if its off? sorry im new to this!!
-Charlie
Old 03-08-2010, 03:24 PM   #4 (permalink)
white90dx's Avatar
When the crank pulley is aligned with the 0* mark on the lower timing cover, the cam gear should be perfectly aligned with the timing mark on the head.
You have to remove the upper timing cover to check this - there is a hole on the cam gear that will allow you to either feel (with a small allen wrench or similar) or see (with a mirror and a light) a small notch on the head. The notch is located directly towards the "top" of the motor, but when the motor is in the car, it is leaning back 10* or so. Removing the spark plugs will make rotating the motor by hand much easier.
This procedure is illustrated in any repair manual out there (Haynes, Chiltons, OEM BGB, documentation with a new timing belt, etc.) Make sure the timing belt is properly tensioned while you are in there too...
-Charlie
