Cruise
LIGHT IS ON
Getting Signal from SET terminal
YES
Getting Vaccum &
no Leaks
All lights on dash work!
No E brake or
low brake fluid signals
Brake lights work on & off no sticking. assumng
pedal switch is ok
swapped out
Whole cruise control assembly with one I knew worked
Today checking signals to Cruise assembly and actuator??
Any ideas Thank you
90 camry DX 231k Auto 4 cyl....Very well kept car Everything else on the car works great...even the clock and dome.
PS.. Noticed someone ran a wire from the start wire from ignition to the little clip wire on the solenoid. I assume they were having Neutral Switch issues. IT WILL START NOW IN ANY GEAR Not Safe I Know! I should install a new NS Switch and relay by Dr.J.
Ok Thanks Again..... The Camry Man
