5S-FE stalling after hard stop? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2010, 01:17 PM   #1 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
My daughter is now driving my '91 Camry, and she said that it's stalling out on her during hard stops (how many time this has happened, I don't know ).
It's an automatic, 4 cyl, right around 100k miles. Runs good otherwise. My wife said she should just be more careful driving, which would be a good idea.
Seems as though I've seen this issue with other cars as well, coming to a hard stop and the engine stalls.
Any idea what could be causing this?
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 03-14-2010, 05:39 PM   #2 (permalink)
Gameroom cash: $812301
View zythr's Photo Gallery
Does it jerk before it stalls?
zythr is offline   Reply With Quote
Old 03-14-2010, 06:36 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Check for code "51" if it present, the TPS may need asjustment [4pin type] or replacement [3pin];
if no code is present, check the intake hose for cracks and Dashpot for the throttle valve, if eqipped.
Doctor J is offline   Reply With Quote
The Following User Says Thank You to Doctor J For This Useful Post:
HomeGrown (03-14-2010)
Old 03-14-2010, 07:33 PM   #4 (permalink)
HomeGrown's Avatar
Thanks doc, I will check into that. I'll have to have her go to Autozone to pull the codes... but not sure if they can do OBD-I
Zythr, no jerk before stall, just like the engine drops RPM's too low and it stalls.
Old 03-15-2010, 12:33 AM   #5 (permalink)
View Invincibility's Photo Gallery
Jumper wire the terminals TE1 and E1 in the data link connector under the hood, turn on the ignition switch (don't start engine) and count the blinks of the CEL. That will give you the trouble code.
Invincibility is offline   Reply With Quote
Old 03-15-2010, 09:04 AM   #6 (permalink)
Gameroom cash: $302555
The car is OBD1 and Autozone will not be able to pull the codes. You will have to jumper TE1 and E1 as Invincibility stated and count the flashes. The procedure and what the codes mean will be in any manual. If you do not have a manual you can downlaod one for free at the top of the Camry forum over at AutomotiveForums.com. The manuals are stickied there at the top and are a free download. Download the generation 2 manual.
Mike
Old 03-15-2010, 05:54 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The transmission may be slightly overfilled with fluid which can cause slow downshifting. Check the level carefully to verify.
-Charlie
Old 03-15-2010, 06:50 PM   #8 (permalink)
HomeGrown's Avatar
Thank you guys, I will follow-up when I get a chance.
