Reporting findings from problem
Hello there,
I did the paperclip test it was EXTREMELY HARD because you have to get the correct size paperclip then you have to clean/wipe off the dialectical grease so you get a good connection. Eventually I got it and it rendered code 21 Main o2 sensor as follows below details.
Main oxygen
Sensor Signal
Main oxygen sensor circuit
Main oxygen sensor
ECU
During air–fuel ratio feedback
correction, voltage output from the
main oxygen sensor does exceed a
set valve on the lean side and the
rich side continuously for a certain
period.
My question now is can someone please advise me what website or section in the manual that will give me instructions on how to change the Main O2 sensor. Thanks for your help as I don't have a clue.
Dave
