87 Camry ? about idle dropping low after starting the car when it is hot? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2010, 01:02 AM   #1 (permalink)
View hardyrxp's Photo Gallery
Hello to all,
I have a 87 Camry 2.0 5 speed and have a problem with the idle dropping low when I start the car ONLY after it is extremely hot (been traveling far). The weird thing is it only does it intermittently and it can easily be fixed by either giving the car a lot of gas (revving up the motor) or turn the car off (or let it conk out) then restart the engine. Okay so I am giving up here the following is a list of what I have done to fix the problem.....
egr valve replaced & cleaned, egr valve solenoid/modulator inspected and tiny filter replaced, all vacuums lines inspected visually and by hand thoroughly, sensors i.e. tps and numerous others unplugged while the engine was running to test them and make sure they were working properly. In addition throttle body cleaned thoroughly, pcv/hose/tube cleaned & replaced. So again I am perplexed here as to what to check next or where to look? Can someone please help/advise me here and what to look for next and what they thing it might be. I am sure someone on these forums has had it happen to them or something similar look forward to hearing from you thanks.
Dave
hardyrxp is offline   Reply With Quote
Old 04-02-2010, 06:22 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Did you not get sufficient answers the first two times you posted this question?
-Charlie
Old 04-04-2010, 12:44 AM   #3 (permalink)
follow up
You are correct I did not get answers sufficient please advise me here thanks.
Dave
Old 04-05-2010, 04:13 PM   #4 (permalink)
white90dx's Avatar
Dave
Please post any updates, things you have tried or more detailed descriptions in the original thread so that any new viewers can follow the full story.
Remember, you are asking for help - make it as easy as possible for those that may want to help out.
-Charlie
