The clutch pedal assembly is separate from the brake and gas. You will need to swap the brake pedal to make room for the clutch pedal though.
Do you have a full donor car to work with? If so, you can figure out the differences pretty easily. You will have to modify the starting circuit a bit and re-wire the reverse lights, among other things.
-Charlie
