FIRST .... pull of the washer hose to hood and blow compressed air backwards to the washer tank. I have unclgged many this way but still needs to be cleaned out.
Passenger Side under front fender and There is no fuse I know of
You will see some 10mm nut and bolt holding the rock cover
remove rock cover shield to expose the washer tank and motor wires
get a drain pan and jus pry out the black washer motor Rubber seal and screen.
Clean out tank and screen
Reinstall into tank on workbench
pour water in tank
hook 12 volt to motor terminals ( each way )
Make sure motor pumps now or replace motor.
reinstall tank and SCREEN THE FLUID WHEN FILLING or you will plug up the pump screen again!
Hope this helps
Happy Easter to all
Remember the reason for the season ?
