OK, so you pull the pump take it with you to order the new pump. Make sure the parts shop Counterman shows you a picture of the front and the rear to be sure it matches yours. (Gasket will be included)
Your going to have to loosen the timing belt, to replace this water pump it appears. If so, you might consider replacing the timing belt if you have not within the last 60,000 miles. Read up and research how to do this, it's not rocket scientist stuff but it's critical that all the timing marks be alighned when the work is done.
So ahead and pull those plug wires off with needle nose pliers as close to the top of the plugs as you can get to. There is a metal attachment piece inside that rubber boot and that would be best to attempt to yank on. Be prepared to buy new wires. They can be tested by your parts shop personnel to confirm they are good. Mark which wires go where on the cap and on the engine. Put electrical grease (only) on the plugs and you won't have this problem again.
And PLEASE!! no drilling OK?? That's scary talk.
Tim
(mr2tim)
SupercharZed ToyZ
A Toyota Race Team since 1986
Originally Posted by Damea
ok so now i got a couple questions
im pretty sure the water is coming from the water pump, located behind timing belt?
once again why would water pour from this hole when i put it in my rad???
i cant get my spark plug tubes off..... its like thier siezed or theres water pressure built up.... is this possible and how to fix it???
i am about ready to cut the boots and start drilling, but am wating for some reply
no water in oil.... car started right before i stared to tare into it(no broken timing belt)right?
anyones opinion will be greatly appreticated
