Difficulty of Head Gasket Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2010, 04:39 AM   #1 (permalink)
AnimatedMechanic's Avatar
View AnimatedMechanic's Photo Gallery
Has anyone ever changed the head gaskets in the 2nd Generation V6? How hard was it and do you have any tips and tricks in doing it? Thanks.
2009 Toyota Venza V6 FWD
1991 Toyota Camry V6 LE
1987 Toyota Camry LE
1989 Toyota Camry Base (Retired)
1993 Ford F-350 XLT 4WD Lifted
AnimatedMechanic is offline   Reply With Quote
Old 04-08-2010, 05:54 PM   #2 (permalink)
View Kingdom934's Photo Gallery
I've heard people doing their belts on the 2VZ. A little tight. For the head, I don't remmeber anybody doing the head and post up a DIY on the forums. Might also wanna do the water pump and belts while your down there. Waiting for the rest of the Gen2 to add in
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 04-23-2010, 03:32 PM   #3 (permalink)
How much would a professional job cost? I don't have the time and skills to change it and would like to know how much people usually pay for a repair like this so I don't get ripped off.
Old 04-23-2010, 11:43 PM   #4 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
I was quoted $1100 here on Big Island of Hawaii but the guys shop rate is $110/hr. That's for an 88 Camry LE with four cylinder head gasket and new timing belt and oil pump seals. Water pump, idler pulleys etc were already replaced awhile back. Forgot to add the head would've been rebuilt too.
Ended up replacing oil pump seals and crankshaft seal and timing belt for $500. Used a quarter bottle of Bardarhl's stop leak and it worked great for head gasket supposed leak. Car has exactly 200,000 miles and doesn't burn or leak oil anymore. It was 2qts every tank of gas.
66conv6 is online now   Reply With Quote
Old 04-24-2010, 10:49 AM   #5 (permalink)
View AlmightyCamry777's Photo Gallery
if you have not done the head gasket by now, or for anyone else needing tips:
1. Unless the engine has low miles (well under 100,000), i'd do a valve job at the same time. My last 2 that i did (on other cars) i just removed the old head and swapped it for a rebuilt one at a cylinder head shop. (check the shop out first, find out how long they have been around - that can be a good indication of the quality of work they are likely to do).
I went to one guy who quoted me $600...i knew i could do better on price, so just asked for the parts back and paid his $30 minimum. He got so mad i thought he was going to throw me out of his shop, and i know he would have done a good job, but he was over-priced and i knew it, so that was that! Leaving the mad machinist behind i simply got one already rebuilt from a place called California Cylinder heads for $300 (these are year 2003 prices).
Here's some more tips:
-DO NOT unbolt the cylinder head or manifolds until that engine is STONE COLD. I mean over night cold. You can remove the accesories around it etc. but don't touch the head or manifold bolts until the cold requirement has been met.
Failure to wait until the engine is cold can/will result in a warped head or even warped block that wont re-seal again without a lot of resurfacing.
-When you get to unbolting the head, DO NOT just start removing head bolts and pulling them out. Loosen the bolts in increments and in sequence (again you should do this to avoid warping the head.) you can use the same sequence you can (must) use when it comes time to tighten the head back on.
Here's an example (not necessarily the one toyota says to use but it will probably work in a pinch)
http://z.about.com/d/autorepair/1/0/z/A/41997686.gif
-Naturally you want to do as many maintenance chores at the same time you are doing this as possible while everything is apart anyway. If the water pump has a lot of miles, i'd change that, same goes for the timing belt idlers, and definitely change the timing belt now too.
-a torque wrench is not optional when reinstalling the head it is a requirement. Before reinstalling the head, clean the head sealing surface and the block with acetone or some other non-residue cleaner. Blow out the bolt holes in the head with air if you have it (alot of times they will have coolant in them so make sure to get the holes clean and dry). if you do not have air then piece of paper towel stuffed into the bolt holes will get coolant out, a a gun cleaning bore brush and cleaning rod works well here to clean the threads and holes also.
Examine the head bolts, are the threads clean and unmarred? If they are then the holes in the block are (probably) ok, but dont forget, on many of their engines toyota recommends REPLACING the head bolts with new ones every time the head comes off (im not sure if your engine is one of these).
AlmightyCamry777 is offline   Reply With Quote
