wiring diagrams - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2010, 05:14 PM   #1 (permalink)
View indybeer's Photo Gallery
wiring diagrams
Anyone know where I can find a good set of wiring diagrams for a 89 Camry?
I just recently finished replacing the clutch and CV drive shafts. As soon as I fired it up I noticed the water temp gage is not working...I assumed it was a bad sensor since all signs pointed to it from the troubleshooting I could find about it. But after changing the sensor...the gage is still inop. It appears that there is only 4-5 volts at the connector.
Thanks
indybeer is offline   Reply With Quote
Old 04-13-2010, 05:31 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Check www.camrystuff.com for the diagrams.
What kind of multimeter are you using to check the voltage at the connector? (digital or analog) It shouldn't necessarily read 12V.
Also, which sensor did you replace? The one-wire sensor or the two-wire sensor?
-Charlie
Old 04-14-2010, 03:00 AM   #3 (permalink)
-Charlie
I'm using a Fluke digital multimeter. I replaced the two wire green connector coolant sensor
Old 04-14-2010, 03:55 PM   #4 (permalink)
white90dx's Avatar
There's your problem.
Two wire sensor = Water Temp Sensor -> used by the ECU
Single wire sensor = Water Temp Sender -> used by the gauge cluster
-Charlie
