Stock downpipe will not fit, but you can get a cheap eBay downpipe instead. It may need to be 'clearanced' (ie, banged with a hammer) to fit the front swaybar.
You will need a custom front exhaust pipe to mate with the rest of your exhaust (get that upgraded at the same time!).
Try to get the matching oil lines so you can use a stock Celica Alltrac oil pan (or MR2 oil pan with block-off plate for oil level sensor). The feed line will need to be modified so you can run an braded line from the oil pressure port on the head.
-Charlie
