Diag Question: 1990 Camry A/C Compressor or Clutch?
ride: 1990 Camry Wagon, 3sfe, auto 4sp.
issue: when i'm at speed (55mph) and try to turn on the A/C i hear a crazy squeel, it doesn't cool, and the light starts to cycle.
if i am at idle and cycle on the A/C it cools just fine, but if i cycle it off and try to cycle it on without dropping RPM's i get the squeel again.
i recently converted over to r134a because it wasn't cooling as good as it should have been last year, so there is a possibility i could have done something wrong there.
what i need to know is should i suspect the A/C compressor or the clutch (what i'm leaning towards)
i'm aware i should try to tighten the belt before i break out my jump to conclusions mat also..
i'd rather not have to replace the compressor right now, given i just filled the system with gas-- and the fact that i'm on a junkyard budget, so the one i get might be in worse shape.
anything i should pay more attention to or that i've overlooked, anything i should know about a a/c clutch swap on a '90?
