Removing front rotor-I did a dumb thing! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2010, 03:38 PM   #1 (permalink)
View cikemini's Photo Gallery
Ok, I admit it. I did a dumb thing. I need to get the front rotor off to get it turned. I pulled off the caliper and the brake rotor would not move. So, I get a socket pulled off the center big nut and tried to use a 3 arm puller to remove the rotor! You can probably guess what happened next. Well I didn't get the rotor off, but I know have the whole spindle halfway off the steering!
After reading this thread how to remove rotors
now I know how I should have done it, but I didn't
So, how do I get spindle back on without disassembling the whole thing. Boy, do I feel stupid!
Thanks.
Michael
cikemini is offline   Reply With Quote
Old 04-28-2010, 04:17 PM   #2 (permalink)
Oops, forgot to mention it's a 98 Camry.
Old 04-28-2010, 08:08 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
First off, you probably want to post this in the Gen4 section, not the Gen2 section...
That said... did you just push the axle back through the hub partially or did you separate the wheel bearing?
If you just pushed in the axle, just slot it back in there and tighten the nut. If you separated the hub/wheel bearing, you will need to take the whole assembly off and have it pressed back together.
-Charlie
Old 04-28-2010, 09:15 PM   #4 (permalink)
Oops, sorry you are right, posted in the wrong section. My bad.
It is far enough out that a can't get the bolt to thread back on. So, what do I do next? I guess I have to remove it, huh? What is the procedure? Thank you.
Michael
-Charlie
Old 04-28-2010, 11:25 PM   #5 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 04-28-2010, 11:29 PM   #6 (permalink)
Huh?
Old 04-29-2010, 12:52 PM   #7 (permalink)
white90dx's Avatar
Michael
I'll ask again... did the axle get pushed out the back or is the hub and wheel bearing separated.
If its just the axle, you have to just align it and get it back together. Otherwise, you have to take the whole assembly off and get it pressed back together.
-Charlie
Old 04-29-2010, 02:11 PM   #8 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
It most likely an axle got pushed from its splined bore. Spay WD40 on the splines then grab the axle on other side and pull it in to expose the threads, then get on the nut and tighten it .
Doctor J is offline   Reply With Quote
