I wouldn't worry about upgrading your rear diff and trans unless there bad you have an auto or you want taller gears there almost identical to the st165 units except for gear ratio, with the stock Camry transmission you will top out at about 140mph but you'll be pretty quick about getting there, Iv got 252awhp and I raced a guy with a st185 with 293awhp and we were dead even his car would just keep on going to 160 though. I don't think I would want to go 160 in my Camry anyway I got a pretty good suspension setup but that doesn't help the brick like aerodynamics of the car. The st165 trans and diff aren't much of an upgrade but the st185 and especially the st205 stuff are quite a bit stronger.
1988 Camry Alltrac LE 5spd with 1991 3sgte swap
1995 Camry SE V6
