I actually run 92 or 93, for the mpg/cost it is about the same. And most of the top grade stuff around here don't have the corn in it, which I prefer anyway.
That thought crossed my mind that it was engine knock, but I know what that sounds like. I've thoroughly gone through the whole ignition system in the last year. I've also just check and adjusted the timing, it is a 13°BTDC with jumper installed. The timing isn't usually a problem until the temps around here get hotter.
When I used to use cheaper oil filters and did start the car for 4 days or more there would be a "lack of oil" knock. It isn't a crank speed knock, it is more in time with the cams, shims, valves. You know the normal clicking valve train sound. It is that but less lubricated sounding. The strange thing is it just happen a short while from 1500-2500 RPM, seems hit and miss.
Although now that it has been a while I haven't heard it. This is why I was wondering if it had something to do with the use of the Sea foam?
