electrical issues....need some recommendations. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2010, 08:13 PM   #1 (permalink)
View Wangan's Photo Gallery
2nd Generation electrical issues....need some recommendations.
Okay so the headlights turn on the dashlights trn off. That's one. Two, the windows and locks stopped responding at the same time. Its rainy season down here in Florida and my front windows are stuck down. Where should I start looking. I searched briefly and found the rheostat may be bad with the dashlight issue, according to another thread. The locks and windows have me stumped. Fuses are all okay from what I see.
http://i4.photobucket.com/albums/y11...3385Medium.jpg
Here's my camry ^
Current: B+G Springs, KYB GR2 Struts, Erebuni Bodykit(uninstalled), 3SGTE/E52 swap, Crane HI-6S Ignition Box, Crane Timing Retard Controller.
Plans: Here
Wangan is offline   Reply With Quote
Old 05-20-2010, 12:27 AM   #2 (permalink)
View drugal's Photo Gallery
The locks and windows share a circuit breaker, "30A Power CB". It's located in the left kick panel, and you may have to manually reset it if it tripped.
For the dashlights: Turn your headlights on. If the glovebox light still works, it's probably the rheostat. If the glovebox light doesn't work, check the 15A TAIL fuse (do your tail lights work?) and then the tail light relay. The circuit is set up so that if your tail lights fuse blows, you lose all your dashboard lighting.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
The Following User Says Thank You to drugal For This Useful Post:
Wangan (05-20-2010)
Old 05-20-2010, 12:36 PM   #3 (permalink)
Reset it by pulling it out with the battery still connected on the car?
Here's my camry ^
Plans: Here
Old 05-20-2010, 01:35 PM   #4 (permalink)
Pushed in the little button on the circuit breaker and problem solved. Also found my Clifford black box in the process.lol surprisingly that breaker being reset also fixed my dash light issue so no new rheostat needed. Now I gotta figure out why the digidash lost the tach signal.
Here's my camry ^
Plans: Here
Old 05-20-2010, 05:36 PM   #5 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
Could you give a good description of where you found that reset button on the circuit breaker?
stanno is offline   Reply With Quote
Old 05-22-2010, 11:27 AM   #6 (permalink)
On the top of the breaker there is a metal plate right in the middle of the plate there is a hole. If the breaker pops that hole will have a piece of plastic in it. Push that piece of plastic straight down till it locks in place and that resets the breaker.
Here's my camry ^
Plans: Here
Old 05-22-2010, 03:38 PM   #7 (permalink)
stanno's Avatar
Cool! By the way, is this circuit breaker on the inside of the cabin or in the engine bay?
Old 05-24-2010, 01:38 PM   #8 (permalink)
Inside the cabin. should be under your steering wheel to the right. In front where the door meets the body.
Here's my camry ^
Plans: Here
