Power windows & A/C blower kaput
I was going to go on a test drive to see if the installation of a new coil solves my conking out problem. Fired the car up, everything seems normal but the power windows and the blower for the heat/AC suddeny don't wok anymore!
No "check engine" lights. The lights, horn, engine, power door locks work fine.
I've pulled the easy fuses from the main fuse box and they are OK. Also, the 3 on the positive battery post.
With engine running voltage between battery posts is 14 V.
I'll try to work my way through the wiring diagram but if anyone has any ideas I would be most grateful.
Cheers
