No power to cold start injector
'89 Toyota Camry, 2.0 , U.S. built
Hello All,
Because of intermittent starting problems I ran a wire directly from the positive terminal of battery through a 12v 15 amp push button switch on my dash to the terminal on the solenoid.
The car usually starts on the 2nd crank with push button. I am thinking that because the ignition is only in the run position that there is no current going to the cold start injector. Should I be running another wire from my new switch somewhere for the cold start injector?
drstanton1
