ac blows hot air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2010, 10:15 AM   #1 (permalink)
View mjesberg's Photo Gallery
ac blows hot air
I have a 91 Camry. The ac is blowing hot air. The freon is full. What are possible solutions?
mjesberg is offline   Reply With Quote
Old 07-17-2010, 10:38 AM   #2 (permalink)
View AlmightyCamry777's Photo Gallery
First make sure the a/c compressor pulley is turning. Then make sure the air is coming on (even though its only blowing hot air). Can you hear or feel it come on when you press the a/c button? Does the engine slow down just a little bit?
You may want to have someone work the switch while you watch the compressor pulley - this pulley comprises two parts. The outer pulley (belt driven) turns all the time the engine turns, but it free-wheels, unless you have the air on. When you switch on the air, the inner pulley locks up to the outer one and turns also. This drives the compressor to give you cold air.
If the compressor functions normally, check the fuse, and the switch.
And if the compressor turns normally, and the fuse and switch work, then the compressor could be broken.
AlmightyCamry777 is offline   Reply With Quote
Old 07-18-2010, 04:01 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Originally Posted by AlmightyCamry777 View Post
First make sure the a/c compressor pulley is turning. Can you hear or feel it come on when you press the a/c button?
+1
Something similar happened to me and it was as simple as the connector to the A/C being bad. 5mins later and a new connector and she was all set.
Have you checked the relay by the side of the engine?
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
