We'll need a lot more information to really help out here...
Slow shifting while coming to a stop: recheck transmission fluid levels. It is probably a bit high which will cause what you are desicribing.
Idling high when the car is started is normal. Warm days it should be between 1k and 1.5k rpm. Cold days (freezing or below) it can be has high as 1.8k rpm on startup. It should drop after the engine starts warming up.
You will need to go through all the normal checks to see if idle control is working correctly... make sure there are no vacuum leaks, make sure the throttle cable is set correctly, make sure the sensors are within range/working, etc.
As for the cluck, it is hard to tell whether you are describing a broken engine/trans mount or there is something else wrong. Do some more investigation and see what you find.
-Charlie
