1989 Camry won't start only click (please help please) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2010, 04:13 AM   #1 (permalink)
View omoving's Photo Gallery
I keep getting a click every time I turn the key and the engine won't start.
But maybe after 20 tries or so it will turn on...
Yesterday, I have tried for an hour straight to start it and it won't start, just a click every time...
So I am thinking starter motor... So I am thinking ebay, would this do the job:
http://cgi.ebay.com/ebaymotors/ws/eB...m=390156072458
Anyone have some words on what I have to remove to get to the starter motor? Maybe some pictures? That would help..
Thank you!
omoving is offline   Reply With Quote
Old 08-28-2010, 04:54 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
No need to buy a second hand stater -it could have the same problem. Just get new starter motor solenoid contacts, they should be no more than $5. Here's a write-up.
How to: Replace starter motor solenoid contacts – intermittent starting problem
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 08-28-2010, 11:42 AM   #3 (permalink)
Gameroom cash: $303055
^ What Jimnist said. That 1 click and no start is a common symptom of the starter motor's solenoid contacts having excess wear on them. You can actually varify this problem with a simple test. The next time this happens have someone hold the key in the start/crank position while you go under the hood and tap the starter with a wrench or a small hammer. Give it a good tap, but don't try to break the thing. If it now starts/cranks, you have varified the worn starter solenoid contacts problem.
Mike
Old 08-28-2010, 05:58 PM   #4 (permalink)
1 last question,
Where would I get new contacts?
Old 08-28-2010, 11:33 PM   #5 (permalink)
View PaulPR's Photo Gallery
One of my local junkyards has a electrical shop that sells them. Any auto electric shop would have them. You can get them at Toyota, but their price is way too high. You can also get them online at a place like www.startercontacts.com
Good luck. I've replaced starter contacts on a tercel, camry and tacoma. Seems like they go ~120K or so, before you get the 'click' symptom.
PaulPR is offline   Reply With Quote
Old 08-29-2010, 01:11 AM   #6 (permalink)
AnimatedMechanic's Avatar
View AnimatedMechanic's Photo Gallery
You probably just need a new starter solenoid. This seems to be a common problem with Camry's.
2009 Toyota Venza V6 FWD
1991 Toyota Camry V6 LE
1987 Toyota Camry LE
1989 Toyota Camry Base (Retired)
1993 Ford F-350 XLT 4WD Lifted
AnimatedMechanic is offline   Reply With Quote
Tags
89 camry engine starter
