Distributor oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2010, 01:53 PM   #1 (permalink)
View bellysoldier's Photo Gallery
I just replace the inner o ring in the distributor of my 1989 camry.
Oem has put some it seems paint around the screw shown on the pic.
Do you know what it for and what kind stuff of it ?
bellysoldier is offline   Reply With Quote
Old 09-01-2010, 08:28 PM   #2 (permalink)
View drugal's Photo Gallery
That's torque-seal of some kind. It can prevent the screw from turning, or let you know if the screw has moved. It was used since those screws are critical for the distributor and you don't want them coming out.
I used a small blob of rtv silicone on each screw when I rebuilt my distributor. It isn't necessary, but I would recommend it.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 09-01-2010, 11:43 PM   #3 (permalink)
Does the distributor need High Temp rtv silicone ?
Old 10-16-2010, 12:18 PM   #4 (permalink)
View johnjohnchu's Photo Gallery
Hi,
my 1991 V6 camery has an oil leak near the distributor. Probably need to replace o-ring on the distributor. What kind of o-ring (high temp etc.)? Can it be replaced easily?
Regards,
John
johnjohnchu is offline   Reply With Quote
Old 10-16-2010, 12:26 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
That paint on the screw is a tamper resistant item. It shows when something has been taken apart... sort of like breaking a seal. Very common in electronics. It may also keep screws from becoming loose.
If a distributor is leaking oil externally, the o-ring / gasket is likely the problem. It it leaks oil internally, the shaft or bushings in the housing are likely worn out and allowing oil to flow past them.
Zembonez is offline   Reply With Quote
Old 10-16-2010, 02:13 PM   #6 (permalink)
View PaulPR's Photo Gallery
As was mentioned, if the dist is leaking externally, it's likely the simple O ring that goes around the outside of the housing. If it's leaking internally, there's a conventional shaft seal. The hardest part about replacing the shaft seal is removing the pin that holds the drive gear at the bottom end of the shaft. Unless you've done a great job of cleaning yours, it doesn't look like you have an internal leak.
There's a company in Canada called KBox Engineering that sells the seals/o ring/gaskets.
PaulPR is offline   Reply With Quote
