so i've got a '95 camry with the 5S-FE 2.2 thats about to go to the junkyard
my girl has a '90 camry wagon with the 3S-FE and a few minor problems
the distribitor is about shot-- can i use my 5S-FE distro in place of a 3S-FE? i realize the wiring harness is different and i'll need to compensate for that.
her wagon also has some broken sensors around the water outlet of the block, can i swap the good ones off my 5sfe to the 3sfe?
3S-FE picture 5S-FE picture
i've read that the AC clutch is the same part number between the two engines- is this true?
are there any other parts i should rob off my '95 and store (alternator, radiator, whatever else you can think)
