Please Help! Wifes car wont start... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2010, 07:36 PM   #1 (permalink)
1990 Camry 3S-FE
Big_Z's Avatar
View Big_Z's Photo Gallery
USA Please Help! Wifes car wont start...
Wife says that her 1990 Camry 4cyl wont start sometimes. She says that it does not make any noise, not even a click. She says the radio will come on after several try's. Then it finally turns over. I believe it might be the ignition switch but am not sure. Can you please offer ideas as I'm unemployed and can't afford a wild goose chase. Any info would be greatly appreciated. Thanks for your time.
Big_Z is offline   Reply With Quote
Old 09-20-2010, 09:47 PM   #2 (permalink)
Gen 2 camry Guru
View Darwin686's Photo Gallery
USA Oh how I've been there
I know exactly what is wrong here, its actually very common with this car infact i just repaired the EXACT same problem for 10 bucks i'm going to tell you how to fix your problem. Its your neutral safety switch.
I'm going to assume that when you try to start to car you the dash light and radio goes off and comes back on when your key is back at the ACC position. Sometimes is might act like its starting to turn over and then won't and other times complete silence.
The problem you are experiencing is dirty contacts in your neutral safety switch. These switches actually never go bad per say however after 20 years of use one of two things generally starts to happen. You either build up a ton of dirt in it or it comes out of alignment.
If you have never cleaned the switch it would be a good time to go ahead and do it.
Instead of switching gears push the gear shifter hard into park. If the car starts after pushing it up into park at the same time but when no pressure is applied to the gear shifter then its full of gunk. If it starts after not applying pressure then it just needs adjustment which is easy as long as you have a 12 or 10 mm socket. Can't remember which at the moment.
Go to you local auto parts store and get the following,
1. Metric socket set if you don't' have one.
2. I can of electric parts cleaner
3. 1 small pack of diaelectric grease/bulb grease
4. Phillips head screw driver
5. Automotive pick set. Got mine at kmart for $1.00! WOOOT
First lets locate the switch. While standing in front of the car with the hood up look to the lower right side of radiator down below the battery. You will see the switch on the bell housing. It is V shaped. Mine was filthy and blended in really well.
Disconnect the connector to the neutral safety switch and remove the nut of the front of it. Depending on your model you might have to put the car in neutral to get it off or leave it park.
Remove the switch. You will need a phillips head screwdriver. it is held together with 4-5 screws. Take the screws out you will see a little cheap-o gasket around remove and set aside. Carefully remove the contact arm. It has two contact blades in it that are spring loaded BE CAREFUL if you loose these contacts your SOL.
Use a can of electrical parts cleaner on it switch and clean out the goop. If you have an automotive pick set it will really come inhandy with removing the old dielectric grease.
Get a small pack of dieletric grease/ bulb grease and greasu up the switch. Be sure to clean the contacts and lightly sand them with a nail file so they will make good contact. I removed the springs and stretched them out a bit, after 20 years making them 2mm longer isn't going to hurt just be careful not to over stretch. Grease everything in the switch all contacts, hell everything.
Put it back together and slap it back on and tighten it down.
Now here is the trick and you will need a bid after it is back on you might experience the same problem however if you have a friend that can push the gear shifter forward you can see how the switch needs to be adjusted and make adjustments accordingly. If you take your time you can have this done in a hour.
The Good, The Bad and The Ugly
Now lets say the switch is horribly damaged i.e cracked by a rock or something. You can try to weld it back together or just follow the link below you should replace it, or if you just want replace it you can.
A problem that I've faced is that rebuilds of this switch can last for a few years or a few months. It really depends on your mechanical knowledge.
Be prepared to get dirty. Your best way to access this is not from above but from blow after removing the splash guard on the bottom of the engine.
Click here for replacement part
Darwin686 is offline   Reply With Quote
Old 09-20-2010, 10:43 PM   #3 (permalink)
1990 Camry 3S-FE
Big_Z's Avatar
Thanks for the detailed answer. I will be trying that tomorrow evening. I will let you know if it works for me. Thanks again.
Old 09-21-2010, 02:43 AM   #4 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Do you have to play with your shifter ( move it from D all the way to L, and then back to D) to start it? If not, then i'd say it's not the neutral safety switch.
My guess would be the starter motor solenoid contacts. Here's a write-up.
How to: Replace starter motor solenoid contacts – intermittent starting problem
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 09-21-2010, 09:02 AM   #5 (permalink)
View scarney1988's Photo Gallery
Do you have a DVOM?
Can you read a electrical wiring diagram?
If so I would certainly recommend doing some free diagnosis before doing anything. Not the the above fixes are bad ideas, but what if you went to the doctor described your problem and he recommend a hip replacement without getting an xray?
scarney1988 is offline   Reply With Quote
Old 09-21-2010, 10:16 AM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Battery condition, battery connections or fusible links are the good place to start troubleshooting.
The NS switch has nothing to do with the radio
Doctor J is offline   Reply With Quote
Old 09-21-2010, 06:15 PM   #7 (permalink)
Gen 2 camry Guru
USA
I know the neutral saftey switch has nothing to do with the radio however have you ever noticed when you go to start your car all the lights go out as well as the radio?
This was the solution for me. Turns out one of the two contacts in the switch was not making good contact. I had checked everything from fusable links to wires, I have a new bat, alternator, and thinking it was the starter i changed the starter with no sucess. It wasn't till i noticed that i was going through gears and then pushing it hard into park that itw ould start no problem. When the contact pin was not making contact i would turn the key and all idiot light, dome, and radio would cut off which thinkng about is typical for older cars when you go to start them it sends all power to the starter however without the car thinking it was in park proper it would not start till i made contact. I beat my head against the wall for week troubleshooting this.
Old 09-25-2010, 11:14 AM   #8 (permalink)
Gen 2 camry Guru
Hey bud, Just wondering if you ever found the problem?
