Crankshaft Pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2010, 10:36 AM   #1 (permalink)
View JOET/CAMRY's Photo Gallery
Crankshaft Pulley
Hello,
I did a timing belt change on my 1989 Camry about a year ago and marked the crankshaft pulley with a cutting wheel using my dremel. I did however verify that the outer part of the pulley never moved "before" I marked it. check out the pics below...
This was so I would know if the outer part of the pulley (seperated by rubber from the inner part of the pulley) has moved/turned. I heard from this forum that it can be a problem with the pulley as it gets old. The rubber tends to get dried up and brittle and as a result the outer part of the pulley could turn. If it has turned and the mark on the crankshaft pulley is used to set the timing, the timing will be off.
Just wanted to pass on this info.
JOET/CAMRY
JOET/CAMRY is offline   Reply With Quote
Old 10-12-2010, 10:19 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
This could be aggravated by overly tesnsioned belts,and prolonged use of a/c.
If the timng mark drifts like that then the cars will fail the smog due to timing appeared out of adjustment so in theory low income motorists here in California may get qualified for new pulley replacement.
Doctor J is offline   Reply With Quote
