How about the starter relay, located in the forward block behind the left kick panel, at the top right? It has 4 prongs. Just a thought. Maybe not the issue.
There IS a 30A fusible link "BOX" under the hood near the battery that protects: Ignition Fuse, Igniter, Ignition Coil, Distributor, and Injector. This fusible link (looks more like a square fuse) is located about an inch from the positive batter cable as you see in the following pictures. It's the one on the far right of the 3. You might check this. I can't be sure, but it's a wild guess and at least lets you know where that 30A fuse you're looking for is located. That 30A fusible link DOES have a red & white wire going to it! AND, it DOES come from the Ignition Switch! (I've been studying my wiring diagrams.) It's the one under the black cap marked AM2.
Good Luck! Let us know!
