no idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2010, 09:14 PM   #1 (permalink)
View mecho's Photo Gallery
no idle
got camry v6,1991 replaced spark plugs,wires, igniter , cap rotor , rotor , opened injection ports still stall after couple minutes on running eng. also adjusted idle screw any more suggest will help
mecho is offline   Reply With Quote
Old 11-03-2010, 07:23 PM   #2 (permalink)
Gen 2 camry Guru
View Darwin686's Photo Gallery
2nd Generation
whoa you've been busy.
Your in the right area.
Check the following:
1. Ignition coil
2. MAF
Either could be your problem.
More than likely its a bad coil. Its the bottom part of your distributor. Check to see if you have any cracks in it. If you do then replace it.
Darwin686 is offline   Reply With Quote
The Following User Says Thank You to Darwin686 For This Useful Post:
mecho (11-03-2010)
