Looking for a good quality timing belt kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2010, 06:29 PM   #1 (permalink)
View PaulPR's Photo Gallery
I need to replace my timing belt, etc on my '91 Camry 3SFE. Are the parts shown in this ad good quality?
http://cgi.ebay.com/ebaymotors/Fits-...Q5fAccessories
Does anyone know if Aisin the OEM for the water and oil pumps?
I've got some pretty significant leaks coming from the front of the engine and want to take care of all the "might as wells" while I have the front of the engine exposed. I'm trying to decide if I should plan on just replacing the oil pump gasket, o-ring and shaft seal or the whole pump. The engine has 210K. I'm the original owner and have always changed the oil/filter every 3-5K.
Thanks - Paul
PaulPR is offline   Reply With Quote
Old 11-06-2010, 10:29 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Good Year Gatorback with Koyo rollers or Gates (belt and roller kit);Aisin is OEM pump.
Doctor J is offline   Reply With Quote
Old 11-13-2010, 08:42 AM   #3 (permalink)
View AlmightyCamry777's Photo Gallery
If you can measure the oil pressure, find out if its ok (it must make a minimum of at least 10 psi for every 1,000 rpm in other words, at idle you need a minimum of 10 psi, at 2,000 rpm 20 psi, and so on, to a maximum of about 40 or 50 at which point the relief valve opens).
If the pressure is good, i wouldnt change the oil pump, there's no reason! It lives bathed in oil after all, if its making pressure, and its not too much work to change all the seals like needing a hydraulic press or something, i'd just do the seal change.
(And If your oil pressure does turn out to be too low, chances are the main and rod bearings are worn too so no point in changing the oil pump then either.)
AlmightyCamry777 is offline   Reply With Quote
Old 11-13-2010, 12:30 PM   #4 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
The kit is missing the Oil pump seal and O ring. Unless there is some kind of damage to the pump, that's all I'd replace. Otherwise, the kit doesn't look half bad. Im an OEM kind of guy myself, but that's just me.
http://cgi.ebay.com/ebaymotors/Fits-1990-1991-1992-TOYOTA-CAMRY-4-CYL-TIMING-BELT-KIT-_W0QQcmdZViewItemQQhashZitem2a09d6e14fQQitemZ18055 3703759QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Thanks - Paul
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 11-13-2010, 09:34 PM   #5 (permalink)
View scarney1988's Photo Gallery
I have the gates kit with water pump on my car for about 10k and seems fine. Replacing pump is a real joy, especially if your exhaust is rusty. If you do replace the oil pump, do not forget the gasket that attaches the pickup screan to the oil pump. Recommend just replacing pump oring. Also, recommend inspecting spark plug tubes for oil. If there is oil, I would recommend doing that at this time aswell. Aisin is OEM
Cam Seal
Crank Seal
Oil pump seal
Water pump
timing belt
Accessory belts
Loc-tite for pulley bolts
Valve cover gasket
Tube Sealer
scarney1988 is offline   Reply With Quote
