!991 Camry Reverse & Tail Light Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2010, 05:22 PM   #1 (permalink)
View gordy5077's Photo Gallery
2nd Generation !991 Camry Reverse & Tail Light Problem
I own a 1991 Camry 4Cyl Std. When I turn my headlights on, my running lights come on in the trunk, also. Meaning both filaments in the 1157 bulb illuminate. This car does not have a yellow box in the trunk. I checked all fuses & also checked for a broken wire in the wire lume in the trunk area. Any suggestions? This is driving me crazy!
gordy5077 is offline   Reply With Quote
Old 11-07-2010, 10:05 PM   #2 (permalink)
Gen 2 camry Guru
View Darwin686's Photo Gallery
2nd Generation
Originally Posted by gordy5077 View Post
I own a 1991 Camry 4Cyl Std. I have no reverse lights. Where is the Reverse light switch located? Also, when I turn my headlights on, my tail lights come on in the trunk. I checked all fuses & also checked for a broken wire in the wire lume. Any suggestions? This is driving me crazy!
So your backup lights are controlled by the neutral safety switch located o9n the transmission under the battery.
As for your tail lights I'm confused. You saying when your head lights are on your tail lights are on correct?
1991 Camry 3SFE 263K Miles 34 MPG
Restoring one bolt at a time....
I'll never let it die..........
Darwin686 is offline   Reply With Quote
Old 11-08-2010, 09:44 AM   #3 (permalink)
My Camry is a 5 spd std. I don't see the neutral safety switch anywhere on the tranny. I think it may be under the shifter, but not sure.
When I turn my headlights on, my tail lights in the trunk area also come on. Both filaments on the 1157 bulbs illuminate. I also don't see any tail light relay box (yellow) on my model Camry.
Tags
5spd, 88-91, camry 1991, lights
