all-trac fuel level sensor
I'm having trouble finding info on this. I gather from searching around that the fuel level sensor on the normal FWD Camry is integrated with the pump, but the one on our all-trac is separate. The gauge was always reading all the way low, so I popped the sensor out and messed with it a little bit. When I deflect the float all the way up, the gauge reads full, but if I put it anywhere else, it reads empty. Since I can't find any info on the signal between the sesnor and the dash, I'm not sure if the problem is the sensor or the gauge itself. Does anyone know what this signal should look like?
