headlight problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2010, 09:56 PM   #1 (permalink)
View gcox's Photo Gallery
headlight problems
I have an 87 camry with low beams out and left high beam out. I replaced bulbs and checked the fuses, still not working. The high beam indicator light does not come on with the one working high beam light. Any suggestions??? Where is the headlight relay?
gcox is offline   Reply With Quote
Old 11-15-2010, 11:41 PM   #2 (permalink)
View MWB2G's Photo Gallery
sounds a good deal like a grounding issue.
MWB2G is offline   Reply With Quote
Old 11-16-2010, 04:16 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Is there a difference if you pull the stalk to 'flash' the high beams? Is the car an LE model?
-Charlie
Old 11-18-2010, 03:04 PM   #4 (permalink)
No difference when you pull back the mometary high beam switch. The car is a DX model.
Old 11-18-2010, 03:09 PM   #5 (permalink)
How would I troubleshoot grounding issue. If there is voltage at the harness near the head lamp???
Old 11-18-2010, 07:45 PM   #6 (permalink)
View sayers74's Photo Gallery
you need to get a meter or at least a test light & check your headlight plug for power & ground issues. If theres no power, get a wiring diagram & trace it back til you find power. Same w/ the ground.
1991 toyota pickup ext. cab sr5 v6 3.0 l automatic
sayers74 is offline   Reply With Quote
Old 11-18-2010, 07:47 PM   #7 (permalink)
could also be corrosion on the connectors....corrosion does wacky electrical things.
