1989 Wagon misfire and runs rich
I just bought this 1989 2.0 camry wagon. It has a miss and it is very faint on initial start up. It becomes much more noticeable was it is restarted the second time. It can be hot or directly after I start, kill, and restart. I have replaced cap, rotor, plugs, and wires. The light bule ported vacuum switch was missing/broken off so I replaced it and rehooked up the vacuum lines to it. It helped the initial start up but the miss is still there. I have no vacuum leaks but the distributor is leaking a little bit internally. I have cleaned the inside of the distributor with electrical cleaner. I have also cleaned the throttle body. I have just moved and can't find my repair manual. I was curious if anyone had any suggestions. Thanks, D
