you really need to get a meter. Heck heres a coupon for a free one
http://a.slickdeals.net/attachment.p...9&d=1290218419
If ya cant use that or theres no harbor freight near you, you can get one pretty cheap at most hardware & aparts stores. (less than $10)
your check eng. light should come on when you jump e1 & t1. If its not blinking than you arent hooked correctly. No spark should set a code. Mine gave me a code (code 12 i think) when my pick up coil went out.You just have to crank it for about 10-15 seconds & it should set a code.
If your check engine light never ever comes on, you might have a bad bulb or fuse, but more than likely its a wiring issue (normally ground wires at ecu)
have you EVER seen the light come on?
It should come on when the ign. sw. is first turned on before starting also known as koeo = key on engine off(oil light , charge light , brake light & check eng. light should all be on)
