Oil Light Not Lighting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2010, 05:24 PM   #1 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
This morning as i entered the key into the ignition and switched it to the on position... i noted the oil light didn't come on... i started teh engine and nothing... i popped the hood and checked if the wire was still connected ot the pressure sensor... and it was ok
i shut the engine off and tried again... and the light came on just for a fraction of a second ....
now this evening it did the same thing leaving work... as i started the engine... it came but just barely ...then went off...
I'm thinking the pressure switch is going... but is the car safe to drive... i have to make an out of town trip tomorrow night and i would hate to damage anything...
stanno is offline   Reply With Quote
Old 11-26-2010, 09:46 AM   #2 (permalink)
View sayers74's Photo Gallery
Thats just an idiot light. Chances are youll be fine. You probably have a switch goin out or a bad connection.
I would just keep a close eye on your oil level especially if you have leaks, but go & do what ya gotta do
1991 toyota pickup ext. cab sr5 v6 3.0 l automatic
sayers74 is offline   Reply With Quote
Old 11-26-2010, 09:58 AM   #3 (permalink)
stanno's Avatar
Yeah i do have a small leak at the oil sump bung... but it's a real small leak... and i ensure the level is always where it shud be
Thanks sayers74
Old 11-26-2010, 11:40 AM   #4 (permalink)
youre welcome.
Old 11-26-2010, 06:30 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Just grab a replacement switch from the auto parts store when you get a chance... it should be cheap.
-Charlie
Old 11-26-2010, 09:29 PM   #6 (permalink)
Gen 2 camry Guru
View Darwin686's Photo Gallery
2nd Generation
Quick and easy test.
Unplug the oil switch the bulb should come on.
If the light comes on steady then the switch is going bad.
If the light doesn't come on the you have a bad bulb in the dash.
Granted it is an idiot light but helpful should the oil pump fail.
1991 Camry 3SFE 263K Miles 34 MPG
Restoring one bolt at a time....
I'll never let it die..........
Darwin686 is offline   Reply With Quote
Old 11-27-2010, 01:01 AM   #7 (permalink)
white90dx's Avatar
It's the other way around... touch the wire for the oil pressure switch to the motor (ground) and see if the light turns on. If the switch is unplugged, the light will never turn on.
-Charlie
