Transmission differential fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2010, 12:24 AM   #1 (permalink)
View bellysoldier's Photo Gallery
I just know I need to change transmission differential fluid in my 1989 camry wagon. Can I use the same toyota auto transmission fluid into it ?
And how many qts it needs ?
bellysoldier is offline   Reply With Quote
Old 11-28-2010, 01:26 AM   #2 (permalink)
Gameroom cash: $129205
View blu_91_cam's Photo Gallery
I'm assuming you have an automatic? Depending upon how long you allow the transmission to drain for it takes 4-5 quarts of ATF typically any type III or its equivalent will work doesnt have to be toyota.
blu_91_cam is offline   Reply With Quote
Old 11-28-2010, 01:48 AM   #3 (permalink)
yes, automatic transmission 2vzfe engine.
I have used dexron 2 to change transmission fluid.
I think I was confused.
Transaxle oil and front differential fluid.
Where are they ?
Old 11-28-2010, 09:51 AM   #4 (permalink)
View PaulPR's Photo Gallery
The manual lists two differentials for FWD cars, the SV21 and the VSV21. Both use Dextron II (although I think Dextron III replaced that years ago). It says the SV21 holds 1.7 qts and the VSV21 holds 1.1 qts. If you have an 4WD/All-Trac it's a different ballgame.
When I changed the fluid on my 3SFE equipped '91 Camry, I got one of those hose/valve deals that screws into the top of a 1 qt bottle and bought a length of clear tubing and an angle fitting and filled it from the top side.
I think blu-91 was thinking you were talking about the transmission rather than the diff. (Toyota calls the transmission in these cars the transaxle)
PaulPR is offline   Reply With Quote
Old 11-28-2010, 10:58 AM   #5 (permalink)
Thanks.
